Rebuilding thames barge Cambria
Hi good idea to start again. You should find all you need on the Internet. One thing I have recently learned is that Google does not pick up everything. Try Bing or another of the search engines, it worked for me.
There is a lot on Wikipedia on Thames and river Medway Barges, Cambria is still in use.
The first sail to be hoisted on this barge is the topsail, connected by hoops it picks up the higher cleaner air to get going.
The Sprit sail is hauled up close to the mast, so when it is let go the sail opens straight away.
Note there is no sail boom, it is a loose footed sail and is just 'brailed' off onto the 'horse'. This means that when tacking it all operated automatically, the sheet to the foot of the sail at the clew just slides along the horse.
The rudder mechanism is complicated with left and right hand threaded screwed shafts which is an excellent compact system but does not lend itself to copy in a working model.
It is all looking good so keep us informed on progress.
regards
regards
がいいねしました majorray and AlessandroSPQR
