Stuffing box grease?
開始者 jumpugly
6 返信ies 17 いいねs 最終活動: 3年前
Good Morning Folks!
Thanks so much for the advice!
This is a huge help!
Best to all and keep building!
-- Guy
がいいねしました Doogle and AlessandroSPQR
I have always used petroleum jelly
がいいねしました Doogle and jumpugly
I use plumbers grease,
Thank you Rod and Commodore H! I believe what I have on hand is Tamiya Molybdenum Grease. But, will go with the white lithium!
がいいねしました AlessandroSPQR
If you get a tube of white lithium grease that is all you need to do your drive shafts, Rudder shafts and door latches of your car
VA3ROD
がいいねしました Doogle and hermank and
I like white grease. If I want something heavier Vasoline.
がいいねしました jumpugly and AlessandroSPQR
Hello Gang!
I am curious about which grease is best for the driveshaft in a stuffing box, as well as, a rudder sleeve. I ordered both my stuffing box and rudder from an outfit in China and whatever they are using is black in color, quite heavy, and it seems like a decent product for water usage. But due to all my trial fitting I may have lessened the amount of lubricant in the stuffing box and rudder sleeve. All I have left laying about the shop is an old tube of general purpose Tamiya RC (clear) gear-grease. Suggestions are always greatly appreciated.
Best to all!
-- Guy
PS: This is for light cruising my Lumba-Lumba and not for racing about.
がいいねしました Doogle and Ray and
