MFA Torpedo 800
開始者 Cpt-Pugwash
6 返信ies 22 いいねs 最終活動: 3年前
MFA Torpedo 800
Hi Colin.
When you make videos, please send it at the correct speed, with half the accelerator, but with the camera off... ahahahah!
がいいねしました hermank and Colin H
MFA Torpedo 800
That's a very nice model and I agree with you about the cruising.
A good scale model should cruise nicely at a fast walking pace.
My Caroline manages 13 knots true speed which is a tad fast but half throttle is perfect.
がいいねしました AlessandroSPQR and Cpt-Pugwash and
MFA Torpedo 800
It is a big motor I agree, but all the smaller quality motors peaked near 20k rpm and I wanted the throttle control a slower motor would give me. It should cruise nicely I hope close to half throttle.
May4th be with you!
がいいねしました AlessandroSPQR and Doogle and
MFA Torpedo 800
That's a big motor for a 4ft boat.
Must be a heavy beast, any pictures yet.
MFA Torpedo 800
Thanks Colin.. A lovely craft. You must be very proud of her.
Mine has yet to see the water with me. The little girl is a shade under 4ft.. I acquired used and I'm in the process of refitting the running gear. I had no idea of the condition or service life of the original installation so I am starting from new. Your input is most helpful!!
Regards,
DG
May4th be with you!
MFA Torpedo 800
Good morning DG, my boat MV CAROLINE runs a 4 blade 75mm brass prop running on 12 volts . See the details in my harbour.
がいいねしました hermank and Doogle and
MFA Torpedo 800
If you are running a MFA 800 motor, what size prop are you running??
TIA.. DG
May4th be with you!
がいいねしました Colin H
