Norstar wave prinsess
開始者 TerryH
5 返信ies 20 いいねs 最終活動: 3年前
#6 2
Oops would have helped if we showed pictures
がいいねしました Madwelshman and boatmam and
#5 2
CORRECTION.
The prop shaft coupling that I use was a 5mm POWERFLEX (from modelboatbits).
The 5mm prop shaft that I used was a MAXIDRIVE threaded at the propeller end, but plain 5mm shaft at the coupling end.
The ALIGNMENT TOOL that I used was also supplied by modelboatbits. It is the same size as the Powerflex coupling, but turned from a solid bar of alloy and left in place until the motor mounting and propshaft fixings are completed to ensure a perfect alignment.
When the motor and shaft installation is completed, the Alignment Tool was removed and replaced by the identically sized Powerful coupling to ensure as perfect an alignment as it is practically possible to achieve.
I have used the above combination in several of my Classic Model Powerboats that I have restored over the years, and have never had a failure yet.
がいいねしました Len1 and TerryH
#4 2
I run an M5 prop shaft with a Maxi-Power coupling and took some time to make sure that I had a perfect alignment between the shaft and the motor by using a solid coupling when fixing the motor in position.
Any misalignment between the prop shaft and the motor when using this much power will easily destroy most couplings if they are misaligned.
がいいねしました TerryH and GaryLC and
#3 2
I think my LesRo Rapier is a similar size boat to your Wave Princess (?) and I have been running a similar power motor for the last 3-4 years without any problems.
#2 2
3500 seems like a high kv for a water model. What does this vessel look like?
I use 650kv for tugboats
VA3ROD
がいいねしました TerryH and dave976
#1 2
Today I'm having a mad run of my old girl fitted with a Traxx velineon 3500kv brushless motor wrapped in a cooling jacket. Last time I took it out I destroyed the coupling and no doubt ill do the same today 🤣
がいいねしました RodC and hermank and
