fixing a lift off top deck
I’ll be doing same. Using .080 plastic fir deck. Either plastic I beams or wood as you did. I have carbon fiber flat stock I used as cross beams on hull left too. I just was looking at layout n thinking the sonar dome in now I may fill up with Lead. As the battery pack will be midships n motor more aft. Guess I’ll water test with motor n battery pack just dropped in hull. Cutting deck today so I need to get the wood glue blocks on hull done faster as I’ll be needing to glue deck next week. It is slow going but fun n relaxing.
Howard hager
がいいねしました dave976
