Plastic body Perkasa
開始者 Stephen T
14 返信ies 33 いいねs 最終活動: 4年前
Hi Dave it gone up into room L with all those others projects, even found me old Thunderbirds models with boxes I’ll auction them need some parts. From Battlecrafts for my big Perkasa
Stephen james tucker
がいいねしました dave976 and hermank and
Hi StephenT
I think you are best putting this aside for now. Looks as though it was a reasonable model at one time but fell on hard times and was badly altered to twin prop by someone who did not have the ability or knowledge to complete the task.
I agree with Scratchbuilder that a complete strip out and repair is the only realistic solution. At some time in the future you will be looking for a winter project and this model should provide you with hours of fun restoring to full working condition.
If you are anything like me you will have a whole host of projects awaiting attention.
がいいねしました hermank and RNinMunich and
Hi Stephen.
Is that the Levant Beam Engine near Pendeen.?
Bill👍
がいいねしました Colin H and Nickthesteam
Thanks for the advice on this one I’ll put it away in the loft for a rainy day, I have four other boats requiring degrees off attention so loads to go on with I like other people have multiple retirement things to do like driving a 1840s beam engine 😮😊😊
がいいねしました Scratchbuilder
What a mess! You could fapricate A and P frames for the shafts from brass strip and tube or plastic card and tube. Aerials and masts can be made from plastic tube and rod using remains of the damaged parts and photographs as a guide. Divide the boat into sections and tackle one section at a time, working from bow to stern. Give it a rub down, a couple of coats of primer to kill the old paint and repaint with your chosen scheme. Easy. Just take your time and work methodically....
がいいねしました hermank and Colin H and
Hi Stephen.
That’s very kind of you to make the offer.
Please don’t think I was intimating I wanted it.
I mearly wanted to try to help you out,as a project like yours is a real challenge to me.
It’s a very kind offer,but I will gratefully decline as I have far too many boats on the go and not only that I think the wife would hang me from the yardarm.
Please don’t think me ungrateful.
I will reply to your PM as well.
Regards Bill
がいいねしました hermank and Nickthesteam and
Bill it’s yours if you. Want it to much of a job for me it’s free
がいいねしました Nickthesteam
Hi Stephen.
Thanks for the extra pictures.
Sorry to be a pain but could you post some that are pulled back a bit to show more info inside of the engine room and running gear.Also of the outer running gear.
This is quite a job and I would love to get my hands on the running gear and engine room.
You really have to rip it out and start from scratch again I feel.
The hull needs TLC first.
If I could see wider angle pictures I could get a better idea.
The upper deck aspect you can think about when you have a good hull base.
Regards Bill.
I take it that a single prop comes out the middle and the prop support goes in that slot in the base of the boat between the rudders so where do I go with boat I don’t like ditching things but it’s a mess
がいいねしました Colin H
Perhaps she was in the hands of somebody who was not good with models it’s the bit of 100 by 40 sawn as the motor mounts and he paint job was done with a gusty slosher
がいいねしました Colin H and hermank
Has this boat participated at the landing in Normandy?!?!
It is sad to hat it is so damaged.
I have built the model with 2 propellers and 2rudders. It sails forwards and as well as reverse without any problem. On the inside I always make shure there ‘s an additional re- inforcement that whatever happens the rudder shaftcan’t be damaged
がいいねしました Nickthesteam and Colin H
The lash up is the props not sure it’s better to start again and go with one central prop as they are mighty close to the rudders and th motor mount s are sheared off any advice is welcome on this one
がいいねしました Nickthesteam and Colin H and
Hi Stephen.
Can you post some close up pictures of what you’re after please.
Bill
Does any one make the replacement parts for this boat I have that is a mess broken prop supports top parts snapped off motor mounts broken and so forth it’s been badly painted with gloss enamel all in rubbish no wonder it was free
がいいねしました Colin H
