Smoke units
This topic has been addressed numerous times, on numerous Forums, for probably 15 years. The bottom line appears to be that smoke, other than whit(ish), is probably bad for you and probably bad for your boat. It falls in the same category as pyrotechnics(especially on this side of the Pond where there is always a lawyer at every pond).
One option for actual smoke is to use water vapor, which is usually created by ultrasonic vibration. Again, the color comes out whit(ish).
With the exceptions of coal fired and wood fired boilers, or a diesel, a properly adjusted oil burner should not create much smoke at all and it should be grayish. If it is dark, blackish, then the chief engineer is not paying attention to his firing mix.
I have used, and am using, oil smokers and I have not found, much to my delight and in spite of my trepidation, any oily residue left on my models. I have also tried the ultrasonic water smokers. They work fine, but my preference is the oil version because the smoke does not dissipate as quickly.
Lastly, at a distance the white smoke appears to lose some of it's crispness and when the volume is adjusted it looks about right for oil fired ships.
My two cents.😊
My two cents.😊
