Battery connecting
開始者 Stephen T
8 返信ies 15 いいねs 最終活動: 4年前
Battery connecting
I believe the use of the diodes is to prevent any feedback into a weaker battery when 2 are in use in parallel and thereby causing it to overheat and cause a fire. It is always advisable to charge only one battery at a time and never in parallel
LEN1
がいいねしました RNinMunich and River Rat
Battery connecting
I have used two 7.2v battery packs connected in parallel for some years without any problems. I made a Y lead with Tamiya plugs and sockets. No diodes or other 'extras'. When charging I separate the batteries from the Y lead and charge them separately. This is just my choice, although they could be charged through the Y lead as Martin has done.
Take care to connect the correct leads and you should have no problems. Good luck, and happy sailing !😉
Battery connecting
Thanks Doug on the info for the Schottky diodes. Did not know about them or the parallel power boards. Good to know about.
LEN1
Battery connecting
Hi can you post me photos b
how it’s done thanks
Stephen james tucker
Battery connecting
Hi on my crawler and tug. I have two 7.2v batts wired in parralel which gives me still 7.2v but the extra stamina. Don't do it in series it will double the voltage to 14.4 I have joined the two batts together and and charge them both at same time. Charger handles it. Hope that helps. Martin.
がいいねしました hermank
Battery connecting
Hi thanks for the answer reason I ask the model has a Y harness and two Nimih battery’s but not one of those boards
がいいねしました RNinMunich and Colin H
Battery connecting
Hi Stephen,
Basically; connecting in series doubles the voltage at the same capacity.
Connecting in parallel doubles the capacity at the same voltage.
Thus to give a longer duration time you would need to connect your batteries in parallel, i.e. + to + and - to -. Two 5000mAh 7.4V batts would then give a total 10000mAh of 'nominal' capacity at 7.4V.
BUT: to do this safely both batteries MUST be the same type (make and preferably production batch) and the same state of charge.
Precautions must be taken to prevent a stronger battery from trying to charge the weaker one and maybe causing high back currents to flow which can cause a wiring fire and loss of the model.
This can be especially dangerous when using LiPo batteries.
The two batteries need to be connected via fast Schottky diodes to prevent this.
If you are not au fait with electronics and soldering I can recommend this simple solution;
a 'Parallel Power Board' from Action Electronics, sold by Component Shop, see link below.
Open the link and click on [PDF DATA SHEET] for a complete explanation.
https://www.componentshop.co.uk/p103-parallel-power-board.html.html
がいいねしました MotoPilot and Len1 and
Battery connecting
This something I find difficult to get my head round say if’ you used two 5000 7.4 v battery’s an I right that would give a longer duration time and how to I connect theme up so still 7.4 the motor has a Tanya connection
がいいねしました Colin H
