Propshaft to Motor alignment
I clamp my cylinder motors in place so: 1) make a center drilled actual size dummy motor and put the clamp on it. 2) install a long music wire for the prop shaft thru the dummy motor and temp alignment bulkheads on either side of where the motor goes. 3) Glue/screw/fix the motor clamp to the hull. 4) remove the music wire, the dummy motor and temp alignment bulkheads. 5) install the real motor in the clamp, slide your prop shaft in🎉
