were to use my boat
開始者 jamesbuchanan
11 返信ies 0 いいねs 0 フォロワー 最終活動: 18年前
HI jon
Thanks for that. I have already decided that a bolt on keel is the best option. I have some ideas but a quick chat with someone who has actually used this method will help greatly. Thank you for taking the time to email me.
Kind Regards
dave
pictures
john here couple of pics of my boat, the one with engine bay the boat still bit bow heavy so batteris moved aft to either side of the coupling that did the trick and got her up planning nicely.
when weather Improves and can get someone to be able to use camera will get some shots of her on the move
chiffs
range safety
hI john yes Ive now got my new battery pack, 7.2volt saddle pack, I have the pack mounted either side of shaft in engine bay, she now gets up on the plane not too fast looks very authentic, need someone to take some pics as cant steer the boat and take pics at same time. I get about 10minutes run time, would like to get more than that, now thinking maybe lI po batteries, have you any experiance with them and if so do they give better duration.
cheers chiffs
chiffs
hI john, thanks for your info, as Ive only just finished my model Im bit loathed to start hacking it about to get shallower shaft angle, think I will try for a split battery 7.2 volt and see what happens, will let you know how I get on may take a while as cant get anything here local. look forward to seeing photo of yours on the water.
chiffs
--- ORIGINAL MESSAGE (REPLY ABOVE) ---
ive cut away the central bulkhead , flush with the keel , my battery pack sits along the wide area of the keel , when I rebuilt my model it needed a new propshaft , so when I fitted my new stainless steel unit I filed the shaft hole at a shallower angle , Ive used a minI servo on its side for the rudder control and now on a standard 7.2 volt nicad pack get it running with the front half of the model clear of the water surface ! I will try to get a photo of it running tommorrow weather permitting , Im currently having to operate in the sea as my normal lake is frozen ! !
hI there you say you have mounted motor in fwd compartment and drive battery midships, has that got the boat up on the plane and is the prop shaft and tube not got in the way of battery pack Ie, battery is now high up in the model.
I was thinking to get a split pack of 7-2 volts from components-shop.co.uk to fit either side of drive motor, welcome your comments,
Chiffs
chiffs
Chiffs
chiffs
range safety launch
Chiffs
chiffs
For Sale
HI triumphjon,
I am interested in what you have for slae, boats, boat parts, tools etc. I live in Camberley, Surrey. GU15 1SR
please let me know your post code and address so I can plan a route if you don't mind a visit.
thanks, Tall Paul.
Tall Paul.
Romsey, Hampshire.
were to use my boat
If you have no luck here for a boat site
Go to ModelboatMayhem and ask there. There is plenty of Ozzies on site there,and nice bunch of lads.
Good Luck
were to use my boat
I live in adalaide sa (down under ) and I do not know were to use my boat
any help welcome
deck and hull
hi,
i'm having a problem with my fire boat. I was wondering how I could attach my deck to my hull, but still be able to take my deck off easily. I am building all the parts so any help would be appreciated. I was also wondering if I could use one rudder with two propellors, and if I could how do I know what size to choose (rudder size).
were to use my boat
hi,
i'm having a problem with my fire boat. I was wondering how I could attach my deck to my hull, but still be able to take my deck off easily. I am building all the parts so any help would be appreciated. I was also wondering If I could use one rudder with two propellors, and If I could how do I know what size to choose (rudder size).
