Epoxy glue....how to remove it?
Hi Haggis, l proposed this Question last year l used colins method. My propshaft was damaged so any more damage did not matter. I cut as much off the shaft as possible inside of the boat. Then placed the tip of a soldering iron into the shaft.
I also warmed the out side shaft with a small blowtorch you do have to be very carefull !!!! the glue / epoxy gets soft grip the shaft with a set of grips / pliers and twist gently.
Worked like a dream, good luck stay safe Jim.
