Rebuilding the Dusseldorf FLB 2 (Krick model) Superstructure
開始者 LewZ
4 返信ies 10 いいねs 最終活動: 4年前
#5 2
Very nice looking and well detailed! What scale is this fire boat?
がいいねしました Julio
#4 2
My Fotos vom FLB Frankfurt Scratch Build
がいいねしました premecekcz and Mike Stoney and
#3 2
Yes, I know. I found out a lot of information on the Dusseldorf flb 2 since I was given the partially built model. I have a lot of information on the Dusseldorf on my website. Thanks for responding
がいいねしました Dampfgerd
#2 2
Hallo Das originale Düsseldorfer Löschboot ist über 50 Jahre alt und wurde mehrfach modernisiert. Es wurde auch verlängert
#1 2
As I found it was not really feasible in re-working the kit's (Robbe/Krick) superstructure to clear up the plastic windows, I decided to create a new topic based on replicating the superstructure based on photos of the real fire boat. (Of course this can be applied to other models as well.)
First off, the window transparency was not the only problem. A number of items are incorrect or distorted, missing, etc. Too much to list here.
The overall length of the superstructure is 1-1/4 inch too short. Worse than that there is a step in the forward bottom of the superstructure to compensate for the difference in the height of the forward deck and main deck. That is off by 1/2 inch (too short). No wonder if you compare the model to the real boat photos the model sits too high in the water, kind of toy like. This later part upsets me because I already added strong sheer strakes around the hull. Can't fake this one!
Now that I have the .062 thick styrene I am starting on the structure. I found a pretty good side photo with sufficient quality of the Dusseldorf FLB 2. I already printed it out full size to make measurements from. Next will be to draw (CAD) it to make a template and build the sides. Because of compound curves, I extracted the kit's roof which I will modify and install on the new structure.
My main worry is that the manufacturer messed up on the hull. Visually it looks OK and I have a lot into it. Just need to lower the main deck that 1/2 inch.
がいいねしました Colin H
