Battery Charging
Hi Roy
Thanks for your in depth response, I have 3 x Planet T5's (2.4 Ghz) although usually only 2 are in use at the same time.
The chargers I am currently using are Tronics as sold at Lidl and charge quite fast, however I believe they stop charging when a certain temperature is reached rather than voltage.
As the charging cells get very warm in the process I use a fan to dissipate the heat and this lengthens the time taken to charge, which is why I am suspecting temp prioritises voltage.
がいいねしました RNinMunich
