What power set up for twin propulsion?
sorry, not to mislead anyone, it was a graupner 9.6v neo motor that melted the seasprint esc, and cut out the upgraded electronise esc, not the 12v bb turbo, bit of a typo error there!
This was prior to the gearbox, which has drastically reduced the amp draw. The point I was making was that you need to be careful with the amp draw of the motors, and make sure there is sufficient tolerance with the rating on the esc. I learnt the hard way! and as Peter has stated the electronise esc' s are repairable, otherwise that would have been nearly A£40 and it wasnt mine!, the ripmax seasprint isnt!
Hope that helps
Hope that helps
